Haiku Haikuhelper with Mac in sleep mode
So now you have the need to get a Mac Mini and use it as a home server. Even running the thing can't use more than 5 watts.
Sounds like I may need to look into that..... Any particular version or probably the cheapest will work?
Really the only 2 things you can do is put the hard drive to sleep, and put the display to sleep.  In the Energy Saver pane of System Preferences, you can set both of those.
lupinglade said:
Anything that will run the latest OS is ideal.
I'd like to buy an inexpensive used Mac Mini. What is the minimum O/S (or other specs) I should look for in a less than ideal configuration?
