Hello All:
I've got a moisture sensor in line with a solar/humidity/temp sensor (both of them are powered) running off the 6 channel hub. I've got an odd problem with the moisture sensor - readings are stuck at 110 for moisture and 32 deg f temp. I'm not honestly sure where to look - the s/h/t sensor readings appear to be fine.
One more point of info - the voltage between the +12v and gnd at the sensor is only 2.5 volts and I've confirmed my power supply is putting out 16 at the hub - could this low voltage be responsible and would it affect both the temperature and moisture readings?
Ken
Ken
