I usually wouldn't do this for any device that reads above 20 Lesters in signal strength. I do this for the units that either can't be found or weak signals. The other time I do this is to try to make sure the noise is out of phase form the failing unit if possible. Granted for an entire home system this may not be very practical at all but if you do try it and find some impovement I hope you'll let us know about it.
Are people able to communicate with devices in other phases when they don't have a phase coupler?
Neil
absolutely. I went ~2 years without a coupler without issue. I missed a signal once and decided it was time to buy a coupler (I want 100% reliability). I believe the new LCD tv was causing the signal to miss when it was on (only for the outlet in the same room (on the same circuit).
I felt the $70 for the coupler was cheap insurance so it wouldn't happen again... and it hasn't.
