felixrosbergen
Hi All,
I have my Windows Home Server in the basement but i want to be able to see the screen/desktop in the living room. The server has DVI/VGA output and the TV is max 1080i and has component video inputs.
What should i use to transmit the picture? I have a DVI to component adapter harness that came with the video card.
In the wall I have running from the server to the TV:
- 4 cat5e
- 2 cat6 (1 in use for LAN to run the SageTV HD theater)
- 4 RG6QS ( 1 in use for normal analog CATV signal as backup for SageTV). 2 other Coax's are planned to run audio from the soon to come Nuvo in the basement to a soon to come A/V receiver at the TV location.
I can run new wires easilly if needed.
Basically the plan is to run CQC with the CQC interface viewer on the server and then extend the server video output to the TV and either extend USB for local keyboard mouse as well or use IR to control the CQC interface.
Suggestions are most welcome. I've been looking at component video baluns, but don't know if component cabling is ideal for this.
- 4 cat5e
