I have a few HAI dimmer switches installed and phase coupler installed by the electrician. I downloaded the latest version of the Upstart software from Simply Automated. The version I downloaded from HAI didn't work, because there was no choice to pick interface type. I'm running the software on my laptop, I had to get an usb adapter for the HLC PIM to PC Modular Adapter (36A05-1), which has a female end. I also see on amazon, they do carry a HLC PIM to PC modular adapter with a male end.
I was able to connect to the PIM, sometimes it gave me error messages saying I need a updated firmware 3.5, my PIM firmware version is 1.04. Most of times, it was ok, but has no signal and severe noise. When I tried the network discovery, it did find multiple devices, few times actually showed device ids, but couldn't connect due to excessive noise.
When I tried a different outlet inside the house, no noise and no signal.
Tried reset the PIM by resetting 5/10/2 using a needle, and configured in the Upstart software to set to pulse mode.
I have a main panel and two subpanels, the Phase coupler is installed in the main panel, the light is on (red).
I also tried the dimmer setup mode (tap 5 times quickly with Led blinking), the Upstart still didn't detect it.
Also tried reset the dimmer switch (5/10/2).
