NP Neuro! Now, can someone chime in about the keypads and if they work ok in freezing temps? I need to know about this so I can put in my order:
Also, what kind of experience does everyone have with cold temps and keypads? I want to put a original keypad ELK-M1KP in the garage, since it has the internal temperature sensor. The specs only list 32 to 120 degrees F for the keypad.
My garage is unheated, so it can get down to -10 to -20 F in the winters. Would it still work in this cold of temperatures? I realize that the LCD screen might be a little lethargic that cold, but what if I left the backlight on max? Would that heat the LCD enough to keep it working OK?
Let me know your thoughts about this, because I guess I would need to go with an arming station if none of the LCDs would work.
My car stereo is LCD and is super slow when I start my car up in the cold mornings. After it's been on a little bit and heats up, it works fine. I'm thinking the keypad would be fine if I max out the brightness
I dont have any in unheated areas. I will try and find out from ELK later today. I can tell you that I have tested other brands and the LCD have more problems with heat then cold but i never tested below 30 F so I cant be sure on this one. It is possible ELK has not tested down to -20F.
