The house I just moved in to has an OnQ panel with an OnQ telecom module like this one: http://homeowner.onqlegrand.com/products/1267062-01-V1. I like to consider myself pretty savvy at this whole wiring thing, but for the life of me, I can't get this thing to work. The incoming line is a Linksys VOIP router, and I've verified that the line works by plugging a phone directly in to the router. When I try to wire it up to the OnQ module, I get nothing. I'm punching down on the Line On block per the wiring diagram in http://www.onqlegrand.com/images/pdf/IS-0172.pdf (from the top: Brown, White/Brown, Green, White/Green, Orange, White/Orange, Blue, White/Blue) and I've verified the contact is good. The other end of the cable is a 6-position plug wired USOC 6x6 (White/Green, White/Orange, Blue, White/Blue, Orange, Green). I'm guessing it's something to do with how I'm wiring the 6-position plug, but I'm not sure where to start. Any help would be appreciated.
Thanks.
<EDIT> Doh! guess I should have checked my connections in the punchdown one more time... it's working now.
Thanks.
