Hi all.
I've decided to try and give UPB a go on my Omni Pro II system. I am starting off with one switch (front porch), just to get the hang of it.
I can't seem to get the switch recognized. I've tried configuring in PCA using the "Configure HLC device" I get the message: "ERROR: No Module In Setup" even though I have the switch in setup mode (by tapping the switch 5 times and the LED is blinking)
I have also tried at the console itself (6, 1, #, #) and it says "No module found".
Here is what I've done:
1. Installed the switch as per the instructions. (HAI 35A00-3) ...the home is a new construction, new wiring.
2. Plugged the PIM (HAI 36A00-1) into the Serial #3 port on my OmniProII and plugged it into a wall outlet near the Omni Pro II. (I have also tried using an extension cord to plug it into outlets around the house)
I don't have Upstart, nor do I have the cable (HAI 36A05-2) that I would need to connect it to my PC. I was hoping I could program it from PCA and not have to use Upstart, since it's only one switch.
The only thing I don't have installed is the Phase Coupler on the circuit panel. Is this required?
