Building a new house here. I plan on using OnQ/ALC for lighting. But since I am building I was hoping to have the most future flexibility possible.
I have asked the builder to price out prepping for Square-D or Centralite by home running the electric lighting. However, the electrician wants to meet with me - I am guessing because he will have a few questions, so before I meet with him I wanted to have some answers to give him.
1) If you pre-wire for centralite/square-d (anything that uses a centralized system with remote keypads) how exactly do you prepare for that and meet code. I assume in my case I would be asking that all electric that goes to lighting start from the basement so it would look like this:
Breaker Panel -> (Some sort of enclosure that allows him to star off to each switch/light combo) -> Switch -> Light. Then if I went with square-D or Centralite, I would just wire the HV at the switch using wirenuts to bypass any switching and then break apart the wires in the enclosure and place the the centralite control panel there with control wires from the switches.. is that accurate?
What do I tell him to use for "some sort of enclosure that allows him to star off to each switch/light combo?
Also, centralite says you need a 6 conductor wire for the switches - would cat5 work? I am planning on running cat5 to the switches - but I don't want to run another 6 conductor wire as well.
