I started with HS in another house 7-8 years ago and then added an Elk. I later moved to Insteon and then an ISY. I loved HS version 1 several years ago, but about the time HS2 came out the HS Technology folks fell in love with Zwave and development resources increasingly went toward making HS work with that technology. IMO, the program also became less stable during this phase and depending on which plugins were being used, crashes and poor performance became a problem. My HS crashed often enough that I could never leave for a couple of weeks and have a high probability that things would run smoothly, and much of HS's functionality is highly dependent on 3rd party plugins, so it was difficult to figure who was to blame or how to fix it.
Because of this I find myself relying on my Elk and ISY, and have a new 994 sitting in my office, ready to replace my ISY 99, just for added functionality. Both are remarkably reliable and work well, going weeks without issue unless I do some tinkering and experimenting as I have time (and never, as I recall, crashing to the point they are a problem except for some issues with remote Elk access via the M1XEP, which is the weak link of Elk, but still serviceable).
HS, meanwhile, continues to be a problem. I fired it up on a fairly new install running only my VWS weather software about two weeks ago. It ran fine for several days with only one plugin installed and enabled (ACRF2, to read my Oregon Scientific temp / humidity sensors). But within 24 hours of turning on the VWS plugin to talk to the weather station, the VWS software crashed (it had been fine before HS entered the picture). I've tried running the VWS on a different machine from HS in the past, but somehow whenever I intro HS into the situation, I have a problem. And similar problems have occurred over time with other plugins.
So... I find that HS is a great toy for tinkering, but I just can't rely on it in its present form. It's one thing to WANT to tinker and to NOT rely on a program to "run your house". It's something else to be forced into fixing something just to maintain functionality. So HS is relegated to running toys (at best, and without depending on it) while the Elk and ISY do the real work.
HS is in beta with a new and supposedly very different version in which (as I understand it, but check with others) each plugin will run on its own rather than being tied into the main program so closely. I really hope that works, but am unlikely to test it until it is well out of beta and has proven itself much more reliable than the current program based on discussions on their board from users like Pete. I would test / tinker with it if I had more time, but will instead be focusing my limited time on the new ISY 994 and increasing my home's functionality without (hopefully) sacrificing reliability. I will, however, try to maintain a longer term hope that I can one day return to a more reliable version of a program I once really enjoyed, in HS.
