I moved into a house with an existing security system that had only 8 zones. I replaced the security system with an Elk M1G and am successfully controlling the lights through UPB, and have some windows and all the doors working correctly. But, I have several windows that I can not get to show as closed.
How many windows, and are they adjacent or scattered around?
If they're adjacent, then can you make a reasonable guess which is nearest and which is farthest from the Control Panel, regarding likely wire runs?
I can get to the contacts, and I have the wires homerun to the box, but I cannot get to the wires in between -- so I have no idea if they were run in series or how they are run.
What kind of contacts, surface or recessed? Can you pull out all the wire where they are installed, or just the two wire ends connected to the contacts. If you can get to all the wire, what kind of wire is it: single pair, quad (4-conductor) cable, or what? Any colors involved, or all monotone? Even some of the _old_ twisted pairs had ribbing on the insulation and differentiated wire to help keep it straight.
Are the wires at the control in cables, or twisted or tied together in any form that suggests they are linked? Are there just pairs, no quad (4-conductor) cables?
I've tried ohming wire pairs, and they always show open, but I haven't tried combinations of wires.
Any suggestions on how to diagnose short of trying every possible combination of wires?
Trying every possible combo of wires doesn't take that long.
(1) Take all the wires in a bunch with enought insulation stripped off the ends so they all touch. Hold then so all the wire ends are touching. Call this Bunch "A".
(2)hold one meter lead in Bunch A so it touches the wires.
(3) Separate one wire, W1, from A and touch the other meter lead to it (meter set to Ohms).
(4a) If there is no continuity, you have eliminated that wire. Put it in Bunch "B", all wires without continuity.
(4b) If there is continuity, keep one lead pressed to W1, and divide Bunch A into approximately equal halves and test for Ohms again. Continue dividing the bunch until you find all wires connected to W1. Call this Bunch 1 ( or more probably Pair 1).
(5) repeat the process until you have all wires with continuity paired or bunched, or labeled as not continuous to anything.
The whole process will probably take less time than it took me to compose this. I don't compose very fast.
One more question: Do you still have the old panel, or do you know the brand and model? If it was late-model enough to have 8 zones, it probably used EOLR's. Did you find them? Did you locate any in the orphaned windows?
Okay, I lied. That was three questions.
