Just one big fat output.noshali said:Does it offer multiple outputs like the pd9?
regards
50 amp capable? Do you weld with that thing also?Skibum said:Just one big fat output.noshali said:Does it offer multiple outputs like the pd9?
regards
You can then split and fuse as necessary.
Elk also has a ELK-PD9HC that outputs 400mA per output and multiple outputs can be combined for even higher output.johndoe74 said:Most of my stuffs require at least 1 amp (Cable modem, Switch, Router). And the ELK unit can only output 250ma.
It isn't just a rule of thumb, its THE LAW!noshali said:Thanks. That makes sense. So the rule of thumb for such conversion is voltage time amps.
So a 15amp load at 120volts whould be able to carry a load of approx 1800 watts?
