I have the latest version of Java. Java starts and runs when I go to the chat area, but I never seem to connect. Does Java work, or should I use Trillian instead? Does chat only work at certain times of the day?
Chat should work just fine. You can use Trillian to connect to irc.marstracker.com port 6667, room is #cocoon . If anyone else is having problems with the JAVA interface, please post here.
In Java or Trillian? The Java client should connect by itself, it just hangs at "checking ident" for a minute. In Trillian, you probably need to type "/join #cocoon"
Might you have a firewall issue? Are you at home or work? After "connecting..." you should see "logging in..." so you are not connecting to the server.
the chat server won't ping, so don't bother. But can you bring up marstracker.com and/or irc.marstracker.com in a browser? Do you have any alternative browsers like FireFox or Opera you can try?
I can get to both sites with IE. But still unable to connect to a chat session.
I get:
[19:03] *** Failed to launch Ident server : access denied (java.net.SocketPermission localhost:113 listen,resolve)
[19:03] Connecting...
[19:03] Unable to connect : Software caused connection abort: connect
[19:03] Not on a channel
Just tried chat
Connecting...
Unable to connect : null
I connected fine Thursday.
BTW, Dan, BSR, can you post last nights CQC / AO chat session? I wanted to join, but family obs took precedence.
thanx.
UPS failure killed the server for a few hours, it's back up now. I don't have the log personally because I wasn't there either and forgot to turn it on.
My work supplied McAffee virus protection software package automatically blocks port #6667. Once I opened that port up in McAffee, it works like a champ.
