forgets
so i'm looking into changing my sprinkler pump to be controlled by the elk instead of the little switch inside the weatherproof box outside.. so i've got a question.. the sprinkler pump is your normal flotec .. 230VAC @ 9.6A can i use a ELK-924 for the low to high switching for it.. ? namely what i'm looking to do is use elk's output 3 to turn it on.. i've looked at the ELK-9100 too, but i'd rather save some bucks since the 924 looks like it could get the job done.. neither one is waterproof so i'd just mount them in the waterproof box the old switch is in and run some low current wire into the box to switch it on.. what i want to know though is ... is the threshold of current draw too close to what the 924 can handle.. ? the pump is rated at 19.2A @ 115V or 9.6A @ 230V .. i'm going to be running it at 230V though.. so let me know.. show me some pictures or give me ideas as to how any of you have yours wired... i've tried looking for photo's and examples.. but i came up dry.. thanks in advance for all responses.
