jrfuda
Just an update. I've been happily using WebCamXP for several weeks now and it's been running very stable. Thanks to the gang in the chat room, I was able to figure out why I couldn't get the java client to work and can now successfully use either the java applet, java script or flash client to stream video! I actually posted the solution over at the WebCamXP message board and solved a lot of peoples' problems!
When I get a mobo with another PCI slot (as all mine or currently filled) I'm going to try a PCI solution to get video onto my PC, or at least get some USB 2.0 stuff so I won't have the USB bandwidth issues that I currently have. Then I'll be able to use the full potential - 5 cameras - of the program. The developer is also working on a 10 cam version, but no release date has been mentioned.
