What do I have to buy to get my elk to make a chime like a door bell from my elk speakers?
I don't want to spend alot of money and I kinda have my elk controlling my door bell via a ds10a but when it decides to just go off by itself at say, 3am, its kinda freaky.
KC in KC
Doesn't the Elk have a few locations for recording custom voice responses? You could record a doorbell wav into one of those and have a rule to play it when the doorbell button is pushed. I do this with my Stargate and it is very reliable.
I have attempted this, and actually have it working (if you call a somewhat crackly jetsons sound coming from your speakers working).
The first issue I had was, I wanted to wire my doorbell directly to an input, with no transformers, etc. The only way I found to accomplish this was to buy a non-lighted doorbell. Then it works like a regular input, but you need to put it on Fast Loop Response and adjust that parameter to avoid double rings. A lighted doorbell leaks too much current to use on a regular input. The other option is to use a transformer and the doorbell interface that elk sells.
Step 2 is getting the sound into the Elk. The ONLY way to do this is via the phone. Unless you want to add the ELK sound card, find a way to power it, connect relays to your speakers to switch them between the elk and the card. I bought all the parts for this, but decided it was way too complicated for a doorbell, so I stuck with the phone method. If you time it right you can get ok sound through the phone, but it's tricky.
The positives of this approach over a normal doorbell are: 1.) I now have a doorbell that works even if the power fails, 2.)I can route the doorbell sound to everywhere I have speakers, so I can now hear it when in my home theater, 3.) I can have the elk take actions when the doorbell rings, like page me etc.
So that pretty much sums up your options. I hope ELK chooses to incorporate a more modern way to import wavs into it's future products. I would definitely upgrade to an M1G 2.0 just for that ability.
