I'm trying to make sure I understand this correctly:
(from the Insteon Relay switch page)
So for flourescent lighting, this would be (13 amps * 110 volts) = 1430 watts max
Is that correct? If this is the case then I suspect I don't have an issue with the basement anymore...
13 Amp Capacity
Maximum load is 13-amps for resistive loads, 480-watts for incandescent and inductive loads.
