As UPB has a much stronger (40volt) signal; when a scene(link) is transmitted all devices in the link, maybe 100 devices on a whole house scene,  see the signal (nearly) at the same time. The signal activity on the powerline lasts less then a second.
On a similar scene, how long would Insteon's (4volts) signal bounce around the powerline, before another command can be sent?
Dave
I believe Insteon would send the command and it "may" be repeated several times through the mesh before the next command could be processed.  If the next command comes in before the repeating is completed it "may" be lost (cleanup commands aside).  This is where UPB "may" have an advantage over Insteon.
I also think there would be a LOT less traffic on a UPB system then an Insteon system since there is no repeating of commands all of the time. That alone might minimize problems.
that's why I went UPB.  I just finished installing my house (over the weekend).  29 switches!  It took me 3 hours to get all of them programmed with all the proper Links (to make the 4-way and 3-way switches work properly), as well as to add in the split face plates to allow me to put "more" switches where I needed them (the dining room switch was in a goofy spot, so I "fixed" that by splitting a "closer" US2-40 and making one side control the load, and the other control the "remote".
Works great!  What's really great, is if my Homeseer PC is down, I do NOT need it up to control all the lights.  That is what is great about the links (similar to Insteon scenes).
Mind you, I had my house BUILT with neutrals in every box...so about 12 hours to re-wire...3 hours for software.  I was also shooting from the hip.  I did NOT plan it out ahead of time (or it probably would have taken me less time to program them...).
I vote for UPB.  I don't even have a coupler installed right now...and my signal strength is through the roof for the opposite phase.
Plus, you just CAN'T have better service / support / help, then Martin and his team gives over at Automated Outlet.  I just can't say enough nice things about them.  They are GREAT to work with...in fact is was Martin who sold me on UPB.  I was having trouble with my X10 / Insteon stuff.  He told me to try it out, if I did not like it he'd take it back, I'd just have to pay the shipping.  Boy, I'm so glad he said that.  I've loved UPB ever since!
--Dan
