Hi Pete,
Yes I think we are talking about the same type of A/C,.Here is a link to the type I am looking at installing.
http://panasonic.com.au/products/details.cfm?objectID=2403
Unfortunately for whatever reason I can not open their operating instructions. I have updated the PDF reader but keeps seeing a corrupt PDF file. All of their PDF are the same so I don't know if there is some there that helps. I have contacted their customer support and it is just too hard! The people you speak to are video and cameras and you get we don't have a air conditioning specialist.....now that's scary! Panasonic were the only manufacturer that posted operating manuals so I was hoping the answer my be there but I can't read it ahhhhhh!
Anyway this type of A/C in very commonly used here in Australia and have a IR remote control type thermostat. I am not sure that they actually communicate back to the A/C after you adjust the temp settings. The A/C unit probalbly has a thermostat that it uses to adjust to the new temp setting. By that I mean if the remote thermostat sends down by 3 degrees the local thermostat at the A/C unit would be used its thermostat to detect when a three degree temp change has been achieved.
So it is not or at least I believe it is not "communicating" to the A/C unit. Just didn't know if split system type A/C systems typically made provision for wired thermostats, I agree the A/C unit doesn't know or care if it is a communicating thermostat. It is more do they enable wired theremstats to connected.
I hope your correct in your thinking about " I can't imagine that a manufacturer would not include this feature . . . " I will dig deeper and call into a airconditioning specialist today and see what I can gleem.
It could well be that one manufacturer supports wired and another doesn't.
I will report back and share my findings.
Fleetz
