Ok Guys,
After searching around for the past few days, I'm getting a little lost with lots of various potential solutions that all seem to be missing something or another (or maybe it's just me missing some vital piece of information).
Here's the general plan...
In the centralized location, I plan to locate a 4x8 or 8x8 matrix switcher (to be bought - still mulling over HDMI vs. Component and whether I can/want go with a non-RS-232 solution) along with 3 DirecTV boxes and an HTPC server. From each TV location (zone) I want to be able to control each source component, probably via IR (but I'm open to suggestions). The issue I foresee is that the DirecTV boxes will likely all react to the same signal being sent when I only want one box to react. There appear to be a few solutions - the first of which might be the best, although not necessarily terribly scalable over time should more boxes be added or other multiple same-brand components:
1) Set up the 3 boxes to use distinct IR codes (apparently the later boxes all support several sets of codes). This should work, although each universal remote control (suggestions for appropriate sub-$200 remotes?) in each location will need to then make sure that the 'device' being controlled is set appropriately each time I change video sources via the matrix switch (Harmony remotes seem inherently setup to be good at this, are there others?).
2) Use a Xantech IR router (such as this). This appears to allow me to send an IR code down the pipe that first tells the router which component to control followed by the appropriate IR codes to actually control the device. This seems to be a more elegant and scalable solution to me, but I don't quite get how I combine multiple IR receivers into the input of this device (it has 1 input and 8 addressable outputs).
3) Use CQC and a combination of RS-232/IR (maybe using a GC-100? BTW, how does that unit work - I don't quite GET it?) to control all devices. This is definitely something I want to do down the line, but it will always likely be the 'redundant' approach as I won't always have a CQC IV in front of me and I certainly don't want the WAF to go completely awry when/if the CQC server goes down and Oprah turns into a black screen!
Any suggestions on the best way to distribute control of devices given that the centralized closet will hold most all of the equipment (single DVD/Blu-ray and game consoles will likely remain at appropriate viewing locations).
Mark
Edit: Oh, yeah - wiring isn't an issue... I have access to each room via either basement or attic and there are 2" conduits sent to each major room on each floor.
Mark
