One other point with control that I didn't make.
Control as a trigger is also specific to the action listed. In other words "control on" is only a trigger when you physically act on the device in question and push "on". Pushing "off" doesn't trigger the program.
For example
If
Control switch x is switched on
Then
Else
This program will evaluate to true when you push the "on" paddle on switch x. It will not trigger if you do anything else (fade,off,faston,fastoff,etc). So the above program could never evaluate to false (at least not from it's own if section).
So, if you were pushing anything but a single click to the "off" side of the paddle, your program would not run.
If indeed that is what you did, then the next question is whether the isy is receiving info from the device. Check the main page and follow the status of the device when you turn it on/off. It should change along with your button presses.
And last point, which it appears is not the problem for you, ******Make sure the program is saved and enabled****** I can see from your screen shot that it is, but I can't tell you how many times people make that mistake.
