Don't reject a transformer simply because it does have a timer. They can usually be ignored if desired. Mechanical timers don't affect the price much, and you may not have a choice.I am going to make purchase a transformer that does not have a timer built in.
Now for the big question- where to mount the transformers.
Personally I would forget about all that low voltage crap that is out there today and stick with regular 110v. Yes, you'll have to run conduit or burial rated wire, and get fixtures from a lighting store (HD and Lowes only care low voltage now), but the end results will be much better.
You might get away with low voltage for the sidewalk lighting since you are not trying to throw light very far, but for lighting scenery definitely go with the regular voltage stuff. Trying to light a 20' tall tree with some 12v lights isn't going to happen IMHO.
Thanks for the info.
I am going to make purchase a transformer that does not have a timer built in. I may purchase two smaller transformers so that I can control the path lighting and the landscape lighting better.
On the HA side, the falls and lighting are controlled by HomeSeer.
