LightenUP
In Augusta, a home with the lower two floors all UPB. A mixture of PCS and SA are used. 7 switch panels and multiple transmitters throughout. Actually went smoothly with the split phase repeater installed. 5 breaker panels and communication reports levels at only 30 lesters for all units. I assume the signal is stronger than that because there was very little difference b/w phases and all comm tests were running through the SPR. There was noise from the pool pump which is an Intella Flow variable speed 240v pump. We will filter it even though it was far enough removed that it didn't seem to hinder communication.
All in all I am very excited about how clean everything looked and the performance matched expectations. As time goes by, I'll let you know if anything fails or becomes unstable.
Any suggestions or questions from you could be helpful in case something does comes up.
Matt
Matt
