Leviton Z-Wave: "NOTE: Matching remotes are for use with non RF devices only."
kklarson
I am trying to find Z-Wave switches that I can use for 3 switch (4-way) and 4 switch (5-way) circuits, but keep running into dead ends. I don't have the option of adding new wiring. I do have neutrals in all switch boxes. I thought I might be able to use Leviton VZ00R-1L matching dimmer remotes since the specs (http://www.smarthome...ing-switch.aspx) say "for use with Vizia RF dimming wall switches". However, when you read the instructions (http://www.leviton.c...&minisite=10026), the top section says "Cat. No. VZØØR-1L, Matching Dimmer Remote (For use with Vizia devices only)" and the section titled "4-Way Wiring with Matching Remote (w/LEDs) Application" says "NOTE: Matching remotes are for use with non RF devices only." Can anyone confirm that a "matching remote (w/LEDs)" cannot be used with Leviton Z-wave switches? Can I only use a "coordinating remote (no LEDs)?
Any other recommendations for Z-wave dimmer switches for 4-way and 5-way circuits that have conventional wiring? I ran into a dead-end with the HomeSetting HA14C because of the need for an "additional wire" (http://www.smarthome...A14C-manual.pdf). It looks like the CA3000 also needs an additional wire and isn't dimmable (http://www.smarthome...3000-Manual.pdf). It appears that the GE/Jasco might be an option (http://www.jascoprod...ual-English.pdf), but the 45610 auxiliary switches don't appear to be for sale.
Thanks for any advice.
kklarson
Jasco 3-way: http://www.asihome.c...roducts_id=4519
What Vizia RF devices are you using as you main? Are they Vizia RF or Vizia RF+?
Huh? I think I did my searches for the GE 45610 and that's why I didn't find your link. Too bad that it's almost as expensive as the combo pack, but at least it's an option.
I haven't picked anything yet. I'll have to pick whatever works together, but since I need many more companion/auxiiary switches, I thought I'd start there.
pbeaulieu
Have you looked at using the following combination from Leviton:
Leviton VRI06-1LZ Vizia RF+ 600W dimmer with Leviton VP00R-1LX Vizia + matching dimmer remote with LED locator and brightness desplay?
kklarson
kklarson
No! I hadn't come across that option but it does look hopeful since the instructions don't have the limitation about RF devices. However, same question as above; will standard 4-way installs have a Red as well as a Yellow/Rd wire (or equivalent)?
kklarson
Oh, I think I see how this works. The Yellow/Red wire from the switch just connects to the normal red traveler wire and the Red wire on the master dimmer switch is what goes to the load (light). The black wires don't "pass through" the switch as in a normal install, but are tied together to the black wire from the switch. Is that correct?
pbeaulieu
Sorry but I am not an electrician. I have done a 4-way w/LED but not with dimming.
ASIHome
If you want, give me a call to discuss.
