Light Show Master 2.4.0 now available
Xpendable
We just released version 2.4.0 of Light Show Master on 12/4/2009. Goto http://www.jltsoft.com to see the bug fixes/enhancements and to download the newest version.
  • Changed default.lsm location to application directory instead of where LSM gets
    started from.
  • Now the file dialogs will remember the separate paths to the last loaded show, sequence,
    and media files. Loading a media file from a different folder will no longer
    cause the Load Sequence dialog to default to that directory, for example.
  • Media file selector now defaults to the "My Music" folder for the current user.
  • "Edit Show" screen now displays the name of the currently loaded .lsm show file.
  • Added ability to quickly generate repeated events for 1 to 365 days.
  • Event list in the "Edit Show" screen is now sorted by start date/time.
  • Added a "Clear Events" button to quickly delete all events.
  • Fixed a bug in version checking logic.
Also includes these changes from 2.3.2 released a couple days ago:
  • Fixed "index array out of bounds" error that sometimes occurred when left-clicking outside of the sequence grid.
  • Fixed crash bug when using the “Load Channels From Sequence†button when the sequence selected to load from had less channels than the current sequence.
  • Updated the maximum number of allowable PLM links to 1024 to accommodate current revision PLMs.
  • Added a “Rewrite All Links†button to the Channels Properties window. Clicking this button will reset the “write flags†for all the links so that you can force Light Show Master to reprogram all the links in your sequence. Useful if you’ve performed factory resets on all of your equipment and want Light Show Master to reprogram all the links without having to delete and re-add all the device id’s.
