SteveS
I'm looking for opinions on the location of EOLRs. If you have room do you put the resistor inside sensors such as glass breaks and motion detectors that have some room? If so, do you solder the resistor to the end of one of the two non-power wires and attach it directly to the terminal or do you think the resistor wire isn't flexible enough and may break?
Alternately do you not bother trying to fit it inside the sensor and push it with the wire back into the drywall?
FYI, the sensors I have purchased so far are all NC. It just occurred to me that if I had purchased NO sensors I could have just added the resistor across the two sensor wire terminals.
