The Bullet's are also single chain (single polarity) devices, and as such capable of a max of ~65mbps... The only reason normally to use a Bullet is if you're just replacing older equipment and want them to connect to existing antennas. For what you're trying to do, a pair of
NanoStation Loco M2's would probably do just fine and get you over 100mb. There's also the
nanostation 900mhz model but it costs about triple (per end). If you want to do wireless, it'd be no biggie to drop $98 on to M2 Loco's and see what happens. Any good wireless engineer will tell you 2.4ghz isn't going to pass through trees/foilage - they don't want the callback if it doesn't work 100%... but the reality is you'll see installations all the time where people shoot through buildings or trees, or don't leave sufficient fresnel zone clearance, etc - and it still works.
Otherwise if you like using a single pair of wires from the phone lines that's already run, that
Startech VDSL unit would fit the bill very easily. Basically hook ethernet into one port, a phone jack to a free pair of wires on the other, and you'll be probably around 75mb. According to their datasheet, you'll get 10mb up to 1KM (~3800ft); at 300m (985ft) it says it should be at 75mbps.
Of course wired vs wireless can't be measured the same... the wireless stuff won't have a single chain over ~65mb; but the idea is multiple file transfers going both directions, you can have close to 300mb at a single time because they're going in opposite directions and opposite polarities; if you were to do a single file transfer of a 10gb file, that 75mb VDSL will be faster; if you have several devices going at once, you'll probably get better performance over wireless. The radios also have built in QoS for voice/video if the originating devices tag the packets properly.
It's really just a matter of preference - either one should work fine... the wireless might be perceived as faster because of the multi-chain and qos, and it's cheaper... the vdsl absolutely the easiest way in the world and will likely be the most reliable - and won't require any new learning.
