Low cost remote tempature monitoring
Mike P
Hi. We are buying a second home and I would like to be able to chevy the tempature via the web. Is there an inexpensive way to do this? I currently have an M1 installed in our home and hai stats. That will cost to much for a weekend home. I home is in Lake Placid, NY. Temps sometime drop to -30f. I would just like to monitor the temp. Just to see how the heat is doing.
Mike
Do you have full-time internet service into the house? Have you considered a stand-alone internet-enabled thermostat? This would give you control as well as monitoring. Keep the heat low normally, and turn the heat up while on your way to Lake Placid.
If you have internet available you could use a router with dd-wrt for access and then a USB temp device (can't recommend one but they can be found for about $10 and up). Total cost would be under $100 and some time putting the code together. This is probably about the cheapest you could do this. I think anything plug and play would cost considerably more.
If you don't have internet you might think about a phone device that you could call in to or have it call you when the temps got out of range. No specific suggestions for hardware on this though...
I will have Time Warner cable for Internet access. A web based tstat sounds like the correct approach. Any suggestions?
Mike
In the 1980's I used a Sensaphone device (or like - might have been the Heathkit version). It was very analogue with only dial in or auto dial out features. It did have both internal and external temperature sensors. I remember calling into the box and it would read me status
I did a quick Google and the Sensaphone 1000 kind of looked like what I had. (I might even still have it around).
Here's their web site to their newer products...not sure though if you will find a new sensaphone for less than $100 unless you bought something used.
Sensaphone
You could also maybe put some Elk sensors/thermostat (as you stated) on the wire using a serial to network device...not sure if anyone has done this with the Elk Alarm panel. It probably wouldn't really be too cost prohibitive.
You could use a new 2gig technologies panel with a z-wave thermostat which can be controlled from a computer or smartphone.
No land line is required as all transmission goes over the gsm network.
I would also use a 2gig temp sensor just as a fail-safe.
I believe proliphix specializes in network enabled thermostats.
Yes, Proliphix has been in the business for a long time and has a broad line of products. I have two of these and have been satisfied. They have a free monitoring service that will alert via email or SMS you if the temperature exceeds limits that you set.
