WayneW
When doing a keypad message that can be cleared by the user pressing "*", is there supposed to be a blank line display in its place? For example, I send "abcdef" to the keypad. The second line now rotates between 3 lines: time, temp and abcdef. Once the user presses "*", the second line of the display still rotates 3 lines; time, temp & <blank>. I am not aware of a method for the control to know that the user has pressed "*" to acknowledge the message, is there one? Is there some way to get the second line to simply go back to time/temp automatically? I find the blank display boring & distracting.
When sending text with beep, are all the keypads supposed to beep "in harmony"? It seems that my two keypads take turns, one beeps about 4 times, then the other one beeps about 4 times, back & forth. I think it would be nice if both keypads beeped continuously, rather than ping-pong and with gaps.
When sending text with beep to the keypad, does the user need to go to each keypad to silence the beeping? It seemed to work that way for me and that doesn't seem right.
