Got the M1G up and running. installed the RJ-31X as described (Gray, Brown, Red Green) and the Telco Line (Blue/wh and White/Bl) and red and green to my panel. My phones work and I can access the M1 and operate it via telephone. However, I can't run a communication's test and it won't seize the line.
Should I try to switch the Red and Green on the RJ-31X? Can I damage the M1 by doing so? Should I try switching some other wires?
If a phone extension is wired with the incorrect polarity - would this cause the M1 not to seize the line?
Or did I setup something incorrectly in the M1. I followed page 22 closely (Communicator Setup Checklist) and programmed the M1 to call my cell as a test. But again, it won't seize the line.
Thanks!
Thanks!
