Dogman
We had a huge wind storm and knocked out power for about 18 hours. Afterwards I can no longer connect to the M1XEP either directly via serial port or over the network. I also have CQC and the driver cannot connect. I have checked all the network cables and switches and swapped ports with no luck . In ELK RP when I run the find utility it finds it and I noticed the IP address had changed from what I set up years ago statically. Tried the new IP same result. Then ran the M1XEP utility and it also finds it but the next step in the utility is to ping it and the PING fails. Also pinged it manually from a command prompt same thing . Tried old IP and the new one that the Utility found all failed. Forced a static reset of the IP using a shorting jumper on J2 per the manual instructions checked with the utility and the RP find function and it did reset the IP to the default but still no luck. Have of course powered down multiple times and including router. Lights on network connections all normal. Thinking it must be time for a new XEP. The rest of the M1 works normally . If anyone has any other ideas please chime in. one last thing is in the XEP utility it mentions the XEP is on a different subnet then my adapter but I checked and they are the same. I never mess with any subnets either.
