M1XSP with serial-to-ethernet?
benze
Hi,
I'm looking at connecting my Elk M1G to an Omnipro RC-2000 thermostat. From what I read on the M1XSP docs, the connections are fairly easy and straightforward. But I noticed that the M1G has a max of 7 M1XSP boards that it supports. So my question is can one use a serial-to-ethernet converter to get around this maximum? Basically, using a single M1XSP and a serial to ethernet converter, I can then use a serial-to-ethernet converter on all my RS232 devices and connect them all together via a switch. However, the problem I see with this is that each M1XSP must have a jumper set that specifies what kind of device it is connected to.
Am I off base here? Can one use serial-to-ethernet converters to control several RS232 devices via a single M1XSP, or do the mode switches prevent this? Does each M1XSP have to have end-device specific firmware loaded on each individual board? If so, is the only advantage of using a serial-to-ethernet the ability to have longer runs between the device and the M1G?
On a side note, does anyone have experience using the M1G with an HAI RC-2000 thermostat? Are all settings/programs accessible via the M1G? Can they both be used in conjunction (ie: program the thermostat, but have the M1G override settings under specific circumstances)?
Thanks for any insight!
Eric
There is special firmware for the XSP depending on what device you want to control. So no, it probably wouldn't be easy, but I wouldn't say impossible. You could always hook an XSP to a mini-ITX/Atom board running linux and then handle everything in software. But you'd have to write the software.
Ok. Thanks somewhat what I figured. So basically, the only advantage I could extend from using a serial-to-ethernet would be to make the runs longer without headaches. Either that, or just move the XSP closer to the actual device being controlled. Does that sound accurate?
Eric
Yes, instead of dealing with serial->ethernet converters to extend runs, why not just extend the RS-485 bus? I think you can have something like 10,000 feet on an RS-485 bus. Ethernet only makes sense if your run is longer than a mile, or it's across the internet somewhere.
Only reason I can think of is that it would be nice to keep all the M1G modules together in one place in the M1G can. Otherwise I need to get a small enclosure for the XSP module that I can put within 50ft of the thermostat I'm trying to control with it. Nothing major, just a little bit of a hassle....
Eric
I put a sub panel in my garage so I can avoid having to have multiple runs all the way back to the main can. I'm putting another one in the attic as soon as I get time to finish building my catwalks up there. Having subpanels is a convenient way to reduce the amount of labor it takes to wire new zones or outputs.
