See my post above of why we are charging for some plugin/drivers.
Our decision to charge for some plugins and drivers was an intelligent one that will keep us in business for years to come. New hardware is constantly coming out which requires large amounts of programming resources and inevitably costs Cinemar time and money. I think most users want a company that is profitable and will be around for years to come. Not such a crazy strategy. Users only pay for what they need. Pricing any other way will keep a company at a Mom and Pop level...certainly not our strategy.
Unfortunately Ripper - you happened to jump ship just before the onslaught of releases gearing up to MLServer 3.
We're rolling out things left and right - with updates occuring daily on at least something. Just check out the # of releases to MainLobby alone not counting to other plugins/drivers:
Release Notes for 3.00.19 on 08/09/06
Added
• Library Object: 0019_0075 (Meter)
BugFix
• MainLobby wasn't trying to reconnect to MLServer after loading a scene after the default startup scene
Release Notes for 08/07/06 Updates
Added
• 0019_0072 (Decora Switch Top)
• 0019_0073 (Decora Switch Bottom)
• 0019_0080
• 0019_0081
• 0019_0082
• 0019_0083
• 0019_0084
• 0019_0085
• 0019_0086
Changes
• Updated Scene: 0019_insteon.mls
Release Notes for 08/06/06 - No Version Change to MainLobby
Changes
• Updated Scene: 0019_cable.mls
• JPGLoaderTimed01Second - improved reloading for Panasonic IP Cameras
Added
• Scene: 0019_insteon.mls
• 0019_0069
• 0019_0070
• 0019_0071
• 0019_0100 Displays Live Video from Capture Card 1
• 0019_0101 Displays Live Video from Capture Card 2
• 0019_0102 Displays Live Video from Capture Card 3
• 0019_0103 Displays Live Video from Capture Card 4
• 0019_0104 Displays Live Video from Capture Card 5
• 0019_0105 Displays Live Video from Capture Card 6
Release Notes for 3.00.18 on 08/05/06
BugFixes
• Library Object Not Found would appear when coming from a Scene with no Buttons
Release Notes for 08/04/06
Changes
• Updated Scene: 0019_callerID.mls
• Updated Scene: 0019_weather.mls
• Updated Scene: 0019_nav_media.mls
Added
• Scene: 0019_weather.02.mls
• Library Object: 0017_0050 (Russound Keypad)
Release Notes for 3.00.17on 08/03/06
Changes
• Minor Enhancements for future Trial Users.
• Updated Scene: 0019_media.mixer.mls
Bug Fixes
The following items would stop working after loading the same scene twice
• Time.HourMinutes
• Time.AMPM
• Date.Date
• Date.DayMonthDateYear
• Date.MonthDate
• Date.MonthDateYear
• Date.Year
Release Notes for 3.00.16 on 07/26/06
Bug Fixes
• MLServeCmd.MLCmd|MLCommand~myClient1~Application|maximize wasn't working
• Monitor.TurnOn and Monitor.TurnOff was not working
Added
• Modified MLCmd dropdown to include more commands
Release Notes for 3.00.14 on 07/16/06
Bug Fixes
• When switching to scenes with no background skin, the prior scene bkgd skin was still showing up
• Attempting Client>Server ping to prevent clients from not disconnecting (mlserverconnect.swf - version 3.04)
• Ping feature requires MLServer 3.0.52 or higher
Added
• Library0019: 0019_0300 [Progress Bar - requires 0 - 100 value]
• Library0019: 0019_0301 [Progress Bar with Time Code Display - requires two variables in label field separated by a ~]
• ie: {{mldevicemanager_media_percent_done_001}}~{{mldevicemanager_current_mediatime_0
01}} (will not work with
• First value represents a percentage and must equal 0 - 100
• Second value can be any label but was designed for a timecode display (01:52:31)
Release Notes for 3.00.13 on 07/12/06
Bug Fixes
• Resolve some systems problem of saving out "0" byte files
• When Opening some scenes, all locked graphics would become unlocked.
Release Notes for 3.00.11 on 07/10/06
IMPORTANT: This update requires MLServer 3.0.25 or higher
Bug Fixes
• When changing a graphic through Library List box then moving button using arrow keys, object would cycle through Library objects instead of Moving
• When Opening a Scene while in Design Mode, any objects that were programmed to be nonclickable could not be selected without pressing DESIGN first
Release Notes for 3.00.10 on 07/06/06
Added
• Font: Tahoma
• Library Object: 000_0031
Changes
• Updated 0019_media.mls
• Updated 0019_security.mls
• Updated 0019_media.movies.mls
Bug Fixes
• Display Options had incorrect 840x480 display reading instead of 800x480
Release Notes for 3.00.9 on 06/14/06
Changes
• Associated MLS files with MainLobby again
Added
Release Notes for 3.00.8 on 06/14/06
Added
• Options > Display 800x480 Button
Changes to Library0019
• 0019_0002 (extended to fit 1280 width)
• 0019_0013 (extended to fit 1280 width)
• 0019_0014 (extended to fit 1280 width)
• 0019_0023 (extended to fit 1280 width)
• 0019_0009 (enlarged click area)
Release Notes for 3.00.7 on 06/11/06
Added
• Added MLCmds: (Case Sensitive)
• Can be called from an MLServeCmd of another computer: MLServeCmd.MLCmd|MLCommand~clientname~Application|Move~20~20
• Application|Move~x~y (where x and y are coordinates)
• Application|Shift~x~y (where x and y are relative coordinates - see Options > Display. For a 1024x768 display, -80 is absolute 0)
• IMPORTANT NOTE: The entire designer main menu will move with these commands. Make sure you have saved your scene before using
Release Notes for 3.00.6 on 06/08/06
Added
• Passes MainLobby Version number into MLServer Client Window
• URLEncoding is now being used when communicating between MLServer and MainLobby to support displaying unique characters from MLServer Variables
• MLServerConnect Version Number is viewable on OPTIONS > STARTUP panel (only displays after MLServerConnect version 3.01)
BugFixes
• Text.Multiline wasn't updating
• Text.Multiline wasn't tinting
• Text.Multiline wasn't supporting <br> in MlServer Variables
Release Notes for 3.00.5 on 05/28/06
BugFixes
• Keyboard Shortcuts were not working in Overlays
