kwilcox said:
I'm assuming you like the blue LED enough to stick with the US2-40 and not try the US11-30 which has a red/green LED and can be only configured for up to 4 different UPB links (instead of 8) depending on the faceplate.
kwilcox,
Yes, they are cool
And the LED is _way_ brighter than the old ones, so you can actually see it.
Actually, the reason the dealer is using the new US2-40 is four-fold:
1. The new US2-40 switches are, as Simply Automated says, the best switches they've ever made. He's looking to use the most reliable and capably setup possible.
2. The US2-40 switches have rounded edges and thus fit into his j-boxes. The electricians actually had to file down or clip some of the boxes a tiny bit to get the "less deep" slaves in there. In this retrofit, he doesn't have a ton of room.
3. The new US2-40 switch can be set up to control any load from its rocker--even another one instead of itself (while at the same time still letting another switch turn its load on and off even if it doesn't provide a "direct touch" way).
4. The US11-30 switch is going to be discontinued at some point, and the dealer wants to make sure he can add nodes for a year or so and still have them match. Of course, this is a bit of a problem already because the slave switches are still "first generation", so they have the dimmer green LED--but at least they're not red/green. In all reality, he did use one US11-30 from his demo kit, for the electronic fireplace, because he thought that red would be cool for "fire" and would distinguish it from the adjacent light switch.
Chris
