Here's an interesting question:
We won't be back in the UPB test home for a week or three (and from what I understand, two representatives from Simply Automated will be there on site)--but in the meantime, we ran into one more question:
One of the switches (which is controlling standard 110V lighting) works fine sometimes, but sometimes it boots itself into some kind of troubleshooting or diagnostic pattern. We have to reset it (with the circuit breaker, or by pulling the airgap out and then pushing it back in after a few seconds) to get it to come back online--and then it invariably boots itself back into the mode again after a while.
Here's the pattern it shows on its LED:
GREEN PULSE
BLUE PULSE
BLUE PULSE
BLUE PULSE
[repeat continuously]
Does anyone know what this is? At first glance, the technical gentleman I e-mailed at Simply Automated is not sure--but they're looking forward to figuring it out. If we could figure this out, though, maybe it will lead to finding out what the issue at hand is.
BTW, I also learned (again, a bit of technical wisdom from SA) another important thing: it's good to run separate ground wires to audio equipment instead of using the shared ground in the house. I'm assuming this goes for neutrals too, although you normally get that with separate circuits in the first place.
Chris
