pct88
I have an HAI OPII f/w 3.0 whose ethernet port has failed. I defaulted the EEPROM and RAM and still can't ping or connect via IP. I brought in an Omni IIe f/w 3.11c and it works fine on the same ethernet. So I want to migrate the configuration and automation from the OPII to the Omni IIe, swap it in to the cabinet and ship off the OPII for repair.
Question- I have tried various combinations of exporting, importing and Dealer PC Access "Version Override" without luck moving the configuration. I was told I will have to re-enter all of the configuration by hand. Before I take on that task does anyone have suggestions to simplify the process?
I was able to copy/paste the 150 line of automation from one to the other, but I am not sure that the variable names will properly match up even if I duplicate them with matching case and such?
Yes, I realize that the Russound control won't function on the IIe.
Any suggestions will be appreciated!
