EllisConCo
I am still in the process of getting my sytem (Lumina controller with HI-FI2 and two Omnistats) set up. I am waiting for my serial to USB cable in order to utilize UPStart. I understand that UPStart will allow the change of a switch to a dimmer and vice-versa. My question is this:
If a switch is modified to a dimmer, is this dimmer function only controllable through software (i.e. PCAccess, Snaplink, Haiku) or does it also allow the switch to be operated manually as a dimmer?
I did notice that when the devices for my system were installed, the switches (non-dimming) still had dimmer stamped onto the housing. If the entire switch is changed to dimmer (logically and manually) that would explain why.
As a side note, I put in about 20 HAI switches during the installation of the system. I love them so much I am going to end up replacing darn near every switch!
