What are you using to monitor water pressue? Every pressure sensor I've found is pretty expensive, about $250+. Since I want to measure pressure in several places, that gets real expensive real fast.
Get a square-d well pressure controller. They cost about $20 and come in various ranges, I use a 20-40 (on at 20 psi, off at 40 psi). I have one connected to my M1 to monitor my well pressure tanks. If they drop below 20 psi, the relay contact closes which means something bad has happened, like a pump failure.
I never thought about using that kind of pressure switch to monitor pressure. I'm on a water well, so I have one the controls my pump cycle. Never even though about using one as some type of monitoring device with dry contacts.
In my case, I want to monitor pressure throughout the range, not just alert on low/high pressure (although I want to do that, too).
Ira
