nick_l
Maybe they can go the rest of the year without a recall.
HAHAHAHAHAHAHAHAHAHA. (Sorry, tried to resist. Just couldnt do it)
Nick
I have installed over 50 switches of insteons. ONE failure in all over 3 years now. Maybe it is the installers that are at fault? Or just propaganda.
Do you still use insteon.?I was one of the users that had an ApplianceLinc catch on fire and it was controlling a normal load. One that Smarthome said was an OK load to use.
I even know what part failed and their fix was cut it out. Not replace it with a more rugged part. It only protected the relay contacts. Guess it wasn't that important anyway. The new I2 ApplianceLincs have the part across the relay again. Just a much more rugged set of components.
I have also had paddle switch tact switches fail.
Two where brand new in the box spares. Flaky when unpacked. I don't think an Installer error caused that to happen.
I also had a pair of the SocketLinc Dimmer modules. Maybe you heard of them. They didn't even follow the most basic Insteon Feature of "remembers it state with power restoration". They always went full ON. Folks where coming home to all SocketLincs On or in the middle of the night. Boom all On. Smartlabs came up with a workaround but it was a band-aid that was not acceptable to many. Also had a use with bulb up restriction. I sent mine back on the 30 day unhappy guaranty.
I have also had the newer I2 ApplianceLincs work worse with two Access Point in the system. Than one Access Point and a passive phase coupler. To keep things honest here. Mr. Steve Lee of Smartlabs did offer to assist me with the problem. I chose to reuse my I1 modules and put the I2s in a storage box.
So no Propaganda here.
