motion detector triggering alarm during entry delay
morreale
is this normal? do i need to have a rule to disable to motion detectors once the entry delay starts? should the motion be set to interior follower?
i have 2 entrances that have an entry delay and one is in the path of a motion detector. once you walk inside the alarm immediately goes off.
as usual thanks in advance for the info.
system:
elk m1 gold
Yes. interior follower is the correct setting. An interior follower alarms immediately unless an exterior delay (door) goes into alarm first. In this case it will "follow" the door delay.
