I believe the newer version as well as the older version will work. Here's some screen shots of the newer version.TLCNORM said:I'll be following this post also. I am about to embark on mhy HA for my house. My first order of business will be HVAC. Mike and Rupp gave me great advice so far.
I have MCE 2004. Does Homeseer offer a plugin for that version?
Steve said:Keep your primary control in the Omni. Use software to provide the complementary functions. ML and CQC are competitors. Personally I like CQC better but it is a highly personal decision. With the Omni and CQC you are pretty much set and would not need anything else. Imho, if Homeseer had a robust engine for touchscreens, it would be a better fit.Also if you use mainlobby, which BTW I like the interface how does it tie to the Hoomeseer. Actually, if you had ML, why do you need Homeseer becaue you can get the plug ins for HAI, Russound, Lighting etc
First thing I would do is upgrade to the latest MCE. Its alot better and more stableTLCNORM said:I'll be following this post also. I am about to embark on mhy HA for my house. My first order of business will be HVAC. Mike and Rupp gave me great advice so far.
Imho, absolutely leave lighting to the Omni. Wouldn't you want a robust dedicated hardware controller controlling your lights rather than software running on a pc (regardless of how stable the software is). So, if it were me, and in fact what I do - run as much as you possibly can thru the hardware panel - your Omni. Use the software to only complement it and provide functions the hardware doesn't do - like perhaps TTS, CalledID, stuff like that as well as providing the interfaces on the touch screens.ccap said:I Understand what you mean and thats what I was trying to figure out. I want a robust front end for touchscreens and you mentioned CQC. The only reason I was looking at ML is because its a bit more out of the box and easier to set up...I Think.
Also, if I were to use this type of set up, would I leave the lighing control on the HAI side or do you take lighting to the CQC od ML or another front end? This is where I am getting a bit confused.
Thanks Steve for your help. You are right since I am going to have a new Omni why not run the lighting through it. I will talk to my installer of the omni system and talk to him about which upb lighting he likes. Is one company better than the other??Steve said:Imho, absolutely leave lighting to the Omni. Wouldn't you want a robust dedicated hardware controller controlling your lights rather than software running on a pc (regardless of how stable the software is). So, if it were me, and in fact what I do - run as much as you possibly can thru the hardware panel - your Omni. Use the software to only complement it and provide functions the hardware doesn't do - like perhaps TTS, CalledID, stuff like that as well as providing the interfaces on the touch screens.ccap said:I Understand what you mean and thats what I was trying to figure out. I want a robust front end for touchscreens and you mentioned CQC. The only reason I was looking at ML is because its a bit more out of the box and easier to set up...I Think.
As far as the software goes, they are both good packages, I can not say anything really bad about either. Just don't be fooled into thinking ML is an 'out of the box' solution. Even if it includes a generic prebuilt interface there is alot to setup and customize to your environment. Everybody has their opinion on this, while some people think ML is easier to get up to speed on, I struggled with it and found CQC to be much easier to use once over the initial learning curve (which each has). I also like the network distributed architecture and C++ codebase of it better. Also CQC is 1 price for everything vs ML which is base package plus plugins. That can be debated to death (and has) but I prefer to not have to worry abo0ut plugins adding up. In the end it is a personal decision that only you can make. You sound more like a person to have a CI set it up anyway, rather than mess with it yourself. Either ML or CQC is going to reguire effort on your part if you do it. If you do it yourself, just evaluate both free trials and see what 'fits' your personality that best. If you hire it out to a CI, well then I guess you can go either way as long as you find someone you trust. Either package will handle your Russound out of the box and can support pretty much any of your HT gear either with an existing or newly built driver. With the stuff you already have, there is no reason to throw Crestron into the mix, thats just what your A/V guy is used to putting in.
Thanks David,DavidL said:ccap, Because every setup and situation and needs are different, this requires configuration once a base install is done. This is for any solution on the market.
With MainLobby you can have a whole house audio system with multizone handling, A movie selection and launch system, Weather reporting, XM Radio support, basic ELk or HAI security panel support in a day. Less if you purchase Cinemar's server / UMPC with the software installed and loaded for you.
If you purchase the preloaded servers, out of the box you get the above with as much effort as it takes to plugin a PC to the Internet and turn it on.
Now, once the out of the box functions are setup, you can take as much time as you want to customize it to your individual needs with not much limitation. Or just leave it alone and enjoy.
I have a Gateway MCE. No way to upgrade other than spending $100 on a new MCE software package right?ccap said:First thing I would do is upgrade to the latest MCE. Its alot better and more stableTLCNORM said:I'll be following this post also. I am about to embark on mhy HA for my house. My first order of business will be HVAC. Mike and Rupp gave me great advice so far.
Or buy another that already has it on clearance (i.e. Tiger Direct or the like).TLCNORM said:I have a Gateway MCE. No way to upgrade other than spending $100 on a new MCE software package right?
Yes.ccap said:One other questions guys...
I want to install some cameras around the house. What do you recommend for this? Will the HAI handle that or what is another alternative
