beelzerob
I'm new to using Sage, and I've been given the challenge by the wife: "Make it so my folks can watch general hospital while they're here."
Ok, so here's what I have:
Our OTA reception is pretty poor here. We basically get nothing for analog channels (which is fine, they're going away soon anyway), and we get digital channels for Fox, ABC, and NBC. All of those have a digital broadcast which comes in 480i. We get CBS too, but it's always in some higher form of HD apparently.
The good news is GH comes on ABC, which we get pretty decently in HD and in digital SD.
I resurrected the older PC (FX5200 video card, AMD Athlon something or other, 1 GB memory) for the CQC server and for running the kitchen touchscreen. it works great for that. I thought it'd be pretty neat to be able to use that for anything sage related too, so I don't have to use the more power-intensive media PC (Athlon 64 I think, and some better video card).
So here's what I was able to do....I put the PVR250 card in the lower powered PC and looked to see what channels I could tune in. It did get some channels. I'm guessing those must have been analog channels, and the reception was bad. So, I put in the HD Fusion card and hooked up the antenna to that, and the reception was much better.
I hooked up the media MVP to it last night to see how well it worked. It seemed to be working ok. I was able to tune to HD channels, and the feed to the TV was very stuttery. For HD, is that rendering on the PC and then being sent to the MVP? If so, that explains how bad it was. But the digital SD channels were (relatively) fine. There was some kind of frequent visual glitching. I'm guessing that's a result of the reception, and not the setup?
My HD TV has no problem with the signal coming in. I bought a splitter from automated outlet, so I could take the OTA signal from the antenna to both my HD TV and to the capture card, but I wonder if that's going to make the reception in sage even worse.
So I guess my questions are....is the PC having to render it if it's digital, even if it's only in SD? If so, then the PC is working harder than I want it to. The media MVP is supposed to be the one rendering it, right? Like the HD100 does?
Any remarks or suggestions on my setup? Again I'm new to this. I like how it's working, but the GH scenario has to be pretty rock solid.
And where do I put in the license code to get the "trial" to go away from the media MVP screen?
- A decently powered media PC which at one time was used to render captured OTA HD
- ATSC-110 HD OTA capture card
- Hauppage PVR250 capture card
- DVICO HD Fusion 5 lite capture card
- A lower powered PC which is currently the CQC server (stays on 24/7)
- A media MVP
