I believe/assume/guess that "net metering" means it is direction sensitive, so that it could detect buying versus selling.Do any of you know how it 'net meters'. Since power from the grid comes in over the same mains that my solar power is returned to the grid on how does it differentiate the two? This is all thats holding me back from getting in line for one.
Current meters do have a direction associated with them...for those of you that remember the right hand rule from freshman physics. If you dig through the brultech site you'll see references to the use in systems with solar. I suspect that the 1240 system would work best for this purpose since it has extra channels...
Had to look up right hand rule (slept a lot in physics).
Hope it does work that way so I can keep tabs on local power company and what they say I am selling back (seems like not much for the amount of production I have)
It had best do net metering well, I'll be feeding it two (actually 3, but two small ones are paralled) grid-tied inverters into the system. I think all I'll have to do is run both "hots" from the inverters thru one current transformer. If I've got this wrong, somebody let me know...
I think (on a good day...:blinkthat the way to sense which "direction" the AC current is flowing is that since the inverters synchronize to the incoming AC waveform, that you could see a timing difference in the incoming and outgoing currents/voltages. Thats my best SWAG...
The brultech protocol does take polarity into account for net metering.
It works the same as how they do power factor: the Brultech has to simultaneously sense current (which has an implied "direction") and instantenous voltage (where on the sine wave the voltage is).
Multiplying those together gives you instantaneous power, which could be negative in the event of a net outflow to the grid.
