ccmichaelson said:
First install bro... I assume the enclosure has all the right holes for adding elk-specific components to it. Just thought it would be nice to have everything inside my A/V rack(s) but I guess I'll stick with the enclosure inside the studs/wall and just route wires accordingly between the enclosure and rack.
Sorry. Baby backs were ready and the race was supposed to be starting.
I wanted to add that you should be OK with a 28" Elk can. Elk cans have the pre-drilled holes to mount the Elk-SWGs (card carriers).
With the 28" can, you can install a receptacle in the bottom so you don't need to plug in the transformer elsewhere.
I actually used a 28" can for the main board, battery, xep, rb, dbh. The stock 14" can is below where all the XIN boards live.
You could try and mount the can in a rack but its going to chew up a lot of real estate. If you have the space and can dedicate a whole rack, go for it. Shouldn't be hard to fab some crossbars and bolt the can to them. I wouldn't want to leave the alarm system components out in the open, even if it was in an equipment closet.
You're probably going to need extra power. Lots of threads here about the Elk P212 and other (i.e. Altronix) power supplies.
What about glass break sensors?
You should really think through your power and wiring routes in the can. If you connect all the motion detectors in the main can, you're going to have 24 12v and 24 ground wires to connect together somehow.
