Verify it is fios. They have a dsl option in some areas. There is also two levels of service. For $10 cheaper you can get 10mbps down I think.
If you are truly hooked on cable, order fios (and port your number, it will show up in the cable company system then, call cable to cancel and they will put a specialist on the phone with you. You will get the option to get some of the lowest pricing they offer (which I think will be like the triple play minus a few bucks and one box, not positive on that). They will lock in the rate for two years for you.
I wound up getting more (2 boxes, one a hd dvr) for about the same as my post triple play price. They will buy out your contract to get you back if you switch and want to return (or at least I was told they would). I may be able to save a few bucks if I took them up on it, but as of this time I have no urge to. Based on that, you could try it, see how you like it and switch back if you prefer cable still. I think I wound up getting $100 in gift cards from Verizon as well.
I occasionally has stuttering on my VOIP (I do a lot of conference calls so use it a bit) it was rare but I would notice it at least once a week. Now I never have to worry about that (they did note they would put a tech on the issue if I wanted to stay).
Hope this helps.
Hope this helps.
