So I am curious then; is it OK to push 1 AMP on multiple 22 guage wires for a DIY cat5E POE setup?
It depends on the distance. The wire will have resistance to flow and thus you will lose potential as a direct function of distance. If the voltage drops too much your appliance will not function properly. If your device at the end has a consistent internal resistance you could increase the voltage of your power source to compensate for it (like a 6v transformer instead of 5). However, the drop in voltage is directly related to the amperage, so, if your device sometimes uses .1 amps and sometimes uses 1 amp, you can't just increase the voltage of the power supply and get a flat increase in voltage at the device.
The effect is easily seen by taking an extension cord and plugging a space heater and a light into the end of it. Turn the space heater on and the light will dim. The longer the cord and/or the smaller the guage, the greater the effect. When the space heater is on, the current through the wire increases and the voltage drops at the end of the wire due to internal resistance in the wire. When the voltage at the light bulb drops, so does the current since the internal resistance of the bulb is unchanged (V=IR).
Another way to think of it is that the wire itself is like an appliance that has been placed in series with the appliance at the end of the wire.
An infant is still in the early stages of developement even out of the womb and for a time afterwards.
The nervous system is not all there yet....try doing a reflex activity - tickle the bottom of a baby's feet and look at the response. Then try the same on an adult. Ask yourself and look what else yet is not developed in an infant...
I personally would not utilize a camera with IR illumination in a baby room; that is me.
The new Foscam PT IR's are so bright that they are actually visible to the naked eye as little red dots around the circumference of the camera.
The IR illumination actually is the only thing that I like about this camera because I can see my cars in the garage in total darkness (40 feet or so across to the end of the garage).
The Foscam PT IP camera is definitely low end but a nice intro to the world of an IP PT camera. It looks fine in the garage but is looks obtrusive for the interior of the home (even a white one).
What you are seeing is not infrared radiation. It doesn't matter how bright the IR is, you can't see it. Your eyes are not capable of seeing IR, period. The led's are visible because they are making some red light as well as IR light. Every IR red led camera I have ever owned has that slight visible glow. You can only feel IR. IR is radiant heat.
IR is not at all the same thing as UV. UV is ionizing, IR is not. UV does damage eyes (baby or not), and you can't feel it or see it. IR will hurt (burn) like crap before it is high enough energy to damage you. IR=radiant heat
I don't follow where an immature reflex has any correlation to whether IR is toxic to a retina or cornea. You can't just say an infant is different than an adult in one way and therefore assume that an infant is different in some other way.
Finally, if you don't want IR illumination of your baby, then you have 3 choices. 1) Don't bother putting a camera on your baby at all. 2) Leave a visible spectrum light on. 3) Buy a camera capable of seeing super low lux IR light (that will pick up the IR radiated from your baby's warm skin). Also known as a night scope. But be prepared to spend big money.
