snakevargas
I'm trying to get nx650n wireless sensors to work using an external contact. As per the instructions, I removed the jumper, and connected a NC plunger contact in series with a 4.7k eol resistor. However, the sensor is always reading open, regardless of whether the contact is closed.
I tried a second nx650 and wired the resistor directly across the external contact terminals, with the same result.
The sensors work fine when used with their internal reed switch (and jumper installed), so it's not a wireless reception issue.
I'm using an elk m1 gold.
Any ideas on what I'm doing wrong?
