I'm in the late stages of negotiation on buying my first house, and if everything goes through one of the first things I'll be doing is running some Cat6 cable through the attic and in the walls. Probably won't start off with a full home-run setup (can't justify all of the effort given my limited equipment/usage) and will just go point-to-point between the spare bedroom/office with my PC/router and the living room for my TiVoHD & Blu-Ray player (plus create a second interface to my PC in the living room using a DVI & USB-over-Ethernet interface: http://www.networktechinc.com/usbc5-dvi.html ).
So I started looking into the process of running the cables, and got tripped up on how exactly you get the punchdown jacks & faceplates to fit/stay in the walls. After wandering the aisles of my local Home Depot, I found several options, and was wondering if these were the recommended approached from the folks here - and if the pros/cons I'm seeing match up with real-life experience.
The first thing I found was this - Plastic Old Work Low Voltage Bracket/Box: It is a orange plastic bracket that fits into the opening cut into the drywall, and is secured using two methods: 1) a set of swing arms that pivot behind the bracket and are snugged down with integrated screws, biting into the drywall from behind; 2) drywall screws [not included] that screw into the top & bottom holes directly into the drywall.
On a different aisle, I found this - Leviton Metal Old Work Low Voltage Bracket: It is a thin metal bracket that also fits into the opening cut into the drywall, but is secured using a different method: the metal 'tabs' at the top and bottom are bent back to capture the drywall and hold the bracket in place; and then drywall screws are screwed into the top & bottom directly into the drywall.
At first glance, it appears that the plastic bracket makes more sense - it is more rigid, it has more mechanical advantage in gripping the drywall, it can be removed & replaced, and is non-conductive. However, the metal bracket has one distinct advantage: it takes up less space (has less material).
Could some folks who have done retrofit work chime in as to their preference/experience with these? Or, if not these, what they use instead (a full box, etc.)? I'd like to get started thinking this through in advance, so I don't get caught out late in the game. Thanks.
