Hi,
I've installed some Marmitek SW12 X10 modules (you can find specs here: http://www.marmitek.com/en/product-details/home-automation-security/x-10-home-automation/micro-modules/sw12.php ) to control shutters opening/closing.
I wired and connected them with no problems, but now I'm able to control them only partially from the Omni: I can send ON/OFF commands just fine, I can even send DIM/BRIGHT command but I cannot set a "fixed" level for opening. The command set level to x% is simply ignored.
I defined the modules House code as Extended X10 in the Omni, and the instructions of the modules I downloaded from the link above states that "The unit will also respond to ‘Extended’ code1 X-10 messages of Type = 0. Using these commands enables the unit to remotely set the blind to any desired position".
I'm trying to do exactly this but I simply can't.
Am I doing something wrong? Or is the Omni II simply not capable of sending those commands? I'm using 3.9 firmware version.
As an alternative I might think of sending DIM/BRIGHT commands, but the Omni only allows me to send DIM-9 or Bright+9; do I have to make a series of macro to repeat the +9 until I get what I desire?
