Thank you @grantlewis.
Yes here first generation of the OmniLinkBridge ran fine for me on Docker installed on the ARM based Pine64 then later on the ARM S912 Octocore CPU (TV Box).
It was me that suggested to Tiger to utilize an RPi. I had forgotten all of the issues I had when I did use an ARM CPU. I apologize for this.
Then when updating it one day it wouldn't create the docker instance due to lack of source code for the ARM CPU so this is where I switched over to using an Intel based mini computer.
Hassio was written as an all inclusive OS for the RPi (ARM). It does not include an entire Linux OS but only the pieces you need. It is a bit of a stripped down Linux OS and this does cause some issues with some plugins who source is only Intel CPU based.
Note too that Ryan did this installation of the OmniBridgeLink app on an Intel CPU and Intel based Linux and following his GitHub step by step it will work fine using an Intel based CPU. Well and there is no Windows OS today that runs on an ARM CPU. You can emulate an '86 OS in a virtual machine on an ARM CPU but it is really slow. I have installed Windows XPe on an RPi second generation and it is too slow for automation stuff.
